road-runner
Jun 21, 2017Explorer III
happycamper002 wrote:I said "electrical interaction", not "influence". The statement is easy to make because it's true.road-runner wrote:Not withstanding the readings you have from the scope... the above statement is tough to make.
This explanation is not correct. The DC output is driven from its own winding on the eu2000i's stator and has no electrical interaction with the windings that drive the 120 volt inverter.
Certainly (as shown in the Honda schematic) the DC output is derived from a separate sub-winding.
Being separate that they are doesn't mean that one winding has no influence over the other.
Overload on either 12VDC or 120VAC will set off an alarm.Have you actually seen this with the DC output or are you guessing?
The DC output is meant to be higher by design to push electrons to the discharged battery.So you're saying the DC will flow backwards through the diodes. If I don't understand how this can happen I have no business trying to explain anything.
Running at par or lower voltage will cause the charger winding to act like a load thereby making the battery condition worse.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
