ScottG
Oct 15, 2016Nomad
NinerBikes wrote:floridacamper wrote:
Thanks I'll try putting a load on it and running it with seafoam for a few hours
I prefer to put in the right amount of seafoam on a full tank of absolutely fresh gasoline. Then I run it for an hour a day under heavy load. Carb needs the down time to soak and saturate with the seafoam mix in it for a few 23 hour periods, to do the job right. 2-4 days of that should do it.
And that's what I did many times before the last time when I put the half can in. I ran a double dose most of the time and would let it sit.
Nothing happened until I put the half can in and ran it at length.
