Oct 15, 2016Explorer II
A fuel shut off valve will make that generator last as long as you will. You can put new gas in and turn the valve on a year later and it will start up quick. I have a 10 year old chainsaw I use once a year. I empty the tank after every use and then run the carb dry after every use. Buy some Seafoam
