MeandMyLabs wrote:
The following is copied from the Progressive Industries website.
Yamaha Generator
Please be advised the Yamaha Generator Model EF2000iS does not generate enough start-up current which causes the unit to overload. The generator then puts out non-true Sine Wave power. Progressive Industries units are designed to operate only on True Sine Wave power.
For this reason, The Progressive Industries Warranty is hereby void if an EMS Unit is used in conjunction with a Yamaha Generator Model EF2000iS. Any damage sustained to the EMS unit are the sole responsibility of the customer.
I am not partial to any brand and do own a Yamaha 2400is but I thought this to be interesting.
Glad I saw this.. I have a Progressive Industries 30 amp EMS hard wired into my travel trailer. I also have a Yahama EF2000iS generator that I have used with the trailer BUT before I installed the EMS System.. I use the GN plug on the generator. It is almost impossible to unhook the EMS system (due to location) if I ever need to use the generator with the trailer.. Had I known of this issue, I would have purchased the pedestal mounted PG EMS system or a Honda generator.. Oh well.. Live and learn and leave the Yahama EF2000iS generator at home..
