Old-Biscuit
Aug 03, 2017Explorer III
thermal fuse blow when exposed to 190*F.....flame/excessive heat blow back from combustion chamber
T-stat has NOTHING to do with this.
Flame sputtering......
gas flow/air mixing is not in balance
Remove burner tube.......clean with bottle brush
Remove orifice....soak in alcohol and then blow dry.....very low pressure (just pucker up and blow on it) NO poking things thru it!!
Run a wire thru combustion chamber and out exhaust... tie a rag to wire and pull back thru 'U' tube\
Reassemble.
Install new thermal fuse
Fire it up...adjust air shutter so flame is Strong, BLUE and slight roar
DONE..hot water (t-stat will shut down when temp reaches 140*F)
Reassemble.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
