hedge
Nov 30, 2016Explorer
Mine's the BC-30 but I assume pretty similar. I also purchased the extension. I installed mine on a truck camper so I drilled a hole through the wall above the back door and ran the wire inside, from there I hooked to the extension and ran the transmitter up to the front to be as close to the truck as possible.
I then wired it in to the 7-pin plug to get power when in reverse. I also wanted to be able to turn it on at will so I ran a wire from one of my upfitter switches under the truck and back to a disconnect where it goes into the camper. I also had to install a diode on the reverse connection so that it wouldn't back-feed the backup lights when i turn it on via the upfitter switch.
It's worked great for me this way and I get great reception but of course with a truck camper the transmitter is only a few feet away from the gps device.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
