fitznj
Sep 07, 2015Explorer
Running a microwave on a battery/inverter is going to be challenging without a huge battery bank - this was discussed in detail a couple of weeks ago.
If you want to power only certain circuit off the inverter, then go to your fuse panel and switch OFF those circuits you don't want powered. Then plug your main shore power plug into the inverter which is the connected to the battery (as close as possible).
Gerry
Gerry
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
