Calkidd
Sep 07, 2015Explorer
Like I have learned from this forum with some members being pretty blatant, you need to do some research about wiring and the use of an inverter. By asking to run a microwave oven sounds like you might not have quite the grasp on what it is to use an inverter.
I have blown quite a few inverters learning how to hook it up to the panel of the trailer. You need, at the minimum, a DPDT switch to isolate the ground/neutral of the inverter. If you don't POP goes the weasel and I don't mean the breaker.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
