MEXICOWANDERER wrote:
Tradeoff Mena.
You are trading longevity and abusability for CCA
I'll say it again - If you have an inverter high loading issue, purchase (3) group 29-31 AGM batteries and connect them for charging purposes via a "smart" paralleling solenoid, and disconnect with topping or equalizing via a switch.
I can produce EIGHT KILOWATTS of power with 3 AGM group 31 batteries for around 15 minutes. A longer run time would be umm not intelligent with batteries. My 2-volt cells can do it but it takes an F-650 stake truck to haul them.
L-16 batteries are built for 20 hour discharge rates not 5 hour or 5 minute.
I kinda learned this through the school of hard knocks when I switched out our little C's batteries for two X group 31 AGMS. We are heavy power users with everything from Microwave to Keurig coffee maker use when dry camping. TV, hair dryer, laptop etc etc etc. Nothing seems to kill them and the voltage only drops slightly. We have 320 watts of solar helping things along but we notice a definite difference with the new batteries. The only thing that skews it a bit is we changed every light in the unit for LED's al mismo tiempo. The best thing is the AGM's never need water. Expensive puppies though and heavy.
