pryoclastic
Jul 26, 2018Explorer
How do you pull your generator?
The first time I had to drop the genset in our coach to replace the starter I blocked up and dumped the airbags to set the generator down on the blocks. Removed the screws and lifted the coach up.
I thought I was clever but getting everything lined back up in was a PITA.
Now that I needed to drop it again to address fuel flow issues, I bought a motorcycle lift from Harbor Freight:
https://www.harborfreight.com/automotive-motorcycle/lifts-stands/high-position-motorcycle-lift-99887.html
Seems to be working okay for me this time around. I did over estimate where the genset's center of gravity is at but should be able to get things adjusted around when I go back up with it.
So I was wondering what anyone else has used to pull a generator out with.
