ricks99's avatar
ricks99
How long should my battery last (when not in use)?
The title says it all.... I returned from a weekend camping trip about 5 weeks ago. I was fully charged when I pulled into my driveway, unhitched, and put everything away.
Today, I went into the trailer to get ready for our next weekend trip, and had no power. The battery monitor in the power panel showed 1 light (out of four). But none of the lights would turn on (although all the indicators on my panel for water, black/gray tank, etc, all work.)
This is the original OEM battery. We purchased our HTT new in Oct.
I know there are some parasite drains, even when everything is turned off and I'm planning to install a battery disconnect.
DW and I are complete newbies and have no point of reference.... Is it normal for a battery to last only 5 weeks when parked?
  • RoyB's avatar
    RoyB
    Explorer II
    I completely disconnect my fully charged battery bank when parked here over the winter months... It starts out reading around 12.6-7VDC and usually only drops down to around 12.4-5VDC over NOV DEC and JAN...
    During the winter months I can read my batteries with only my Battery monitor meter connected and I usually check on it ever two or three weeks...
    Sometimes when it gets down to 12.5VDC I will hookup my trickle charge for a day or two... This next winter season I will have my 10WATT small solar panel hooked up all the time giving the batteries a slow continuous trickle charge.
    If you let them set you have to pull one of the battery terminals otherwise the parasitic drains will run them down in just a week.. Its best to install a disconnect switch as removing and replacing the battery terminal may or may not keep you with a good solid connection depending how tightly you install the terminal each time...
    Hopefully your batteries are not damaged. Once they go below 12.0VDC it is like driving a nail in their coffin... Do a slow long charge on them using a smart mode charging mode charger. Do it two or threes time in a roll...
    Got to take care of the batteries as they are your lifeline for trailers.
    AT least once a month when sitting here between trips I do a walk around and read the sitting battery voltage. I like to always read at least 12.5VDC or more. Then I switch in the batteries to the trailer and hook up to my garage receptacle which turns on the converter/charger unit and then I look at the battery terminals DC VOLTAGE again and I want to see it jump up to the 13.6VDC or higher depending what smart mode the charger jumps up to. If I don't see the DC VOLTAGE jump up then that tells me my Battery charging system is not working...
    Roy Ken
    No, actually much less than 5 weeks. Probably 100 to 500 milliamps or 5 to 15 amp/hrs drain per day. Battery holds maybe 90 of which you should only use 50 percent or 45. So you need to plug in every 3 to 9 days. Or disconnect a cable and you are good for 3 to 6 months. Even disconnected you need to start tip-top 100 percent charged.
    The 12 Volt Side of Life
  • Sounds about right. There are parasitic draws all over the RV. Install a battery disconnect or plug it in are the only choices.
  • Never leave my rig for more than a day or so unless I disconnect the battery.
