myredracer's avatar
myredracer
Explorer II
Aug 28, 2015
How to determine rating of a new converter panel?
If I were to upgrade our basic WFCO converter to one of the good ones like PD, how do you determine the rating to use? 45, 60, 70 or 80 amps? Is bigger better? We don't dry camp and don't discharge the battery much.
  • The actual rating is probably part of the panel model number.
    Post it here for interpretation.
    BTW when my 55 amp WFCO failed I replaced with a 35 amp. Works just fine. I went with 35 because there was no 25. Although converter mostly stays off now with solar keeping the battery charged. If you want to recharge from a small 1000 watt generator I recommend 40 amps or less.
  • Get the same or slightly larger then your current one.
    If your rig has a 30 amp, you may need to jump to the smallest PD amperage. (45 amp I think).
    Verify size of conductor between the converter and DC distribution panel. Conductor must be able to carry full output load of current. 45 amp should be #6.
    Remember size is not only charge rate but the load of your 12 volt DC loads.
    No. 45 amps is plenty unless the RV is especially large or has some high draw 12v equipment like tank heaters.
  • Why not get one with the same rating as the WFCO you're replacing?
    I have to ask though, if you don't dry camp, why do you care what converter you have?
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 02, 2025
