Old-Biscuit
Jan 08, 2018Explorer III
Fridge Model Number??
From your controls descriptions......maybe N305/306
That #5 Knob 'Temp'
THAT is the gas control knob.
Has temp settings Lo/MED/HI and far right OFF
When on Gas you have to SET which flame is going to be used
Push in knob #5 and turn to HI setting
HOLD knob #5 in while pushing #4 (Piezo) several times rapidly for 5 seconds
Caution:
Do not hold in the gas control for more than 30 seconds.
If there is no flame in this time, wait at least five
minutes before you try ignition again.
If you continue to hold in the gas control, LP gas will collect in the
burner area. This could cause a fire or explosion and result in dangerous personal injury or death
Meter will move into green area when flame is present......continue to hold in knob #5 for 5 more seconds then release.
Turn knob #5 to desired temp setting.......Lo, Med or Hi
LO if ambient air temps are below 50*F
Med for MOST conditions
HI when ambient air temps above 90*F
Note:
Knob #2 Fridge Temp Control
That is the thermostat for AC Operation ONLY
N305/N306 Manual
That #5 Knob 'Temp'
Caution:
Note:
N305/N306 Manual
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
