wa8yxm
Sep 06, 2018Explorer III
There are 3 ways to do it. Easy, Easier and not so easy.
To test POLARITY and voltage get a 15-30 amp adapter and a THREE LIGHT outlet tester. You can find the first in the RV section of some Super stores (IE Wal-Mart) or any RV store and most campground stores the 2nd in the ELectrial of many stores (CW included) and most hardwares.
Plug the 3LT into the adapter and the adapter in. Two green (on most of 'em) means wired right. RED means Wrong. (Legend in printed on the 3LT in case it is different)
Then to check voltage plug in a Kill-A-Watt or measure (If the probs reach) slot to slot. and short slot to hole. (120/120 note that the 2nd test is optional)
Option 2
Plug in a portable Surge Protector like the Progressive Industries PT-30C that does all the tests for you Now easier than that it does not get.
NOTE if your RV is a 50 amp use the proper dogbone and the PT-50C
Or go with the hardwired version.. Again easier than that it DOES NOT GET
FInally the not so easy (But still easy) way.
How to wire a TT-30
This shows a photo of the TT-30 outlet
Neutral to ground should be zero volts
Hot to neutral 120 volts
Hot to ground 120 volts
Happy measuring (NOTE 115 to 125 is ok, 110 is marginal over 125 is not good either).
Option 2
How to wire a TT-30
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 03, 2026
