Kahunna wrote:
Thanks to all for your input.
While prepping for the upcoming Labor Day trip today I again exercised the jacks and again the same jack as last week will not retract.
I think I will take a look at all the electrical connections as Doug suggested, any other suggestions will be greatly appreciated.
Kahunna
The test for a sticking internal jack seal is this----You extend the jacks and let sit extended for 24 hours. Then retract, If any jack sticks then it has bad internal seals. The problem with doing a extension and then retraction within a few minutes or hours is--the extension may temporarily get that bad internal seal pliable for awhile and then it will let the cylinder retract. Whenever I get a customer with this type complaint, I do the 24 hour test. Doug
