dougrainer wrote:
Do you mean the PUMP will not run when engaging the right side? OR, the right side jacks do not extend when engaging? If the pump does NOT run, then the problem is in the Joystick electric control plate. Remove the Round knobs and remove the Joystick black cover plate and clean out or blow out the area around the swivel of the Joystick. There may be dirt/debris stopping the electrical contac. Doug
X2. I do that every now and then on mine. Take the cover off and clean the gunk out. Also clean the electrical contacts but be careful not to lose the tiny springs that actually make the connections when the cover is installed.
