dougrainer
Oct 27, 2015Nomad
rcmiller32 wrote:
If your unit uses the AFT fluid you can change it out for full synthetic ATF fluid. It will flow better at colder temperatures. Might have to empty fill, run then empty and refill to swap most of the fluid out.
http://www.hwhcorp.com/ml23835.pdf
HWH fluid for LOW temps (synthetic). Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
