olddogs wrote:
I was having the same problem. Called my repair guy and had the him look at the jacks. He raised them manually doing the back ones first and then the front. He raised them to max height and then checked the hydraulic fluid level. The tank was near empty. He explained that when the tank gets low that it will suck in air and that will cause the rear jacks to settle back down. Kept it in the up position for at least an hour, drove to local auto parts store and bought two quarts of transmission fluid. Then I added a half quart of transmission fluid and then raised and lowered the jacks on auto several times. Works fine now (24 hours later they are working). When I bought the motorhome a bad jack was found and it was "repaired" but they may have forgotten to refill the fluid tank. The repair guy said that when the jacks are auto leveled they do the front first which led to the problem of the rear jacks sucking air.
1. Fluid is ALWAYS added with jacks retracted.
2. Auto level is dependant on which side/corner is lowest. If the rear is lowest at auto level start, then the REAR jacks extend first. If one SIDE is lowest those 2 side jacks deploy first. If the FRONT is lowest, then the front jacks extend first and then the other jacks then extend.
3. Once the Reservoir is too low, it only takes 1 jack to suck air. But, yes, if the rear jacks deploy last and the reservoir is too low, then once those rear jacks extend and you run out of fluid they will suck air. But if you extended the REAR first, then your problem would have happened on the front jacks when extending.
4. If you have either HWH and the reservoir is filled to correct level, you will have at least 3 to 4 qts of remaining fluid even when all 4 are fully extended
5. If you have Powergear Jacks, the same, BUT, if fluid level is low, the dash down jack will alarm and show jacks down. Doug
