MrLucky1950
Feb 25, 2014Explorer
dougrainer wrote:
Shuttle valve will NOT cause a problem on the pressure side. ONLY when you are retracting the jacks. The shuttle valve does not involve the slide rooms. It is NOT the shuttle valve. Doug
Unless you are using different terminology that I use, the shuttle valve does affect both the jacks and the slides. The symptoms of a bad shuttle valve are that neither the jacks will go all the way down, nor will the slides go all the way out, and when you try and bring the slides in they wont go all the way in.
Dealing with a bad shuttle valve now.
Paul
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
