dougrainer
Sep 15, 2016Nomad
j-d wrote:
Ours looks like a 310 based on comparing the picture in the HWH service manual, with the control panel. Kick Down, No Air Dump, Manual Leveling.
It hasn't ever extended a jack during travel, but I'll start hitting the Store Button when we get underway.
Since the system won't extend any jacks or light up the panel with out the Parking Brake set, do I need to have the system ON to use Store to put it to Sleep?
NO. But, as to never experiencing the dreaded jack extension in travel, it is only when they route the Hyd lines close to a very hot source of heat. Add that source to the outside ambient temps and it may happen. BUT, if the hoses are not installed close to a hot heat source, you will not have this problem. Also, IF the problem happens in transit, you do not have to stop, just push the STORE button and the jack will retract in a few seconds, then the system will go to sleep. You have kick down jacks. This problem is only with straight jacks. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
