base1957's avatar
base1957
hydraulic fluid reservoir weld broke
97 Winnebago Vectra workhorse chasiss, gas
Ok...the reservoir which holds the hydraulic fluid for jack's and slide one of the welds has broken. I have temporarily strapped it up to get home. Not sure I'll find someone willing to weld with a gas tank on the left of the reservoir and a propane tank just forward...any ideas. It's my year for RV repair!
Thanks in advance
  • MrWizard wrote:
    SO
    get another tank, and cut that one off with angle grinder ?
    That's what I'd do.
    Then with some band it clamps I'd be on my way home.
  • SO
    just a thought
    its gong to have to be emptied, cleaned, and lines plugged, before it can be welded
    hyd fluid does burn
  • Tom...it appears the reservoir tank was welded to the frame..at the factory.
  • Sounds like a TIG job for sure! Drain the reservoir, clean it out, purge it with some N2, and you should be GTG for welding!
  • midnightsadie wrote:
    a good weld shop will know how to tackle this its not a hard job.I,ve had things welded close to the fuel tank before.
    A full gas tank is no more a hazard than a full water tank. It's the fumes that ignite, not the liquid.
    Thanks in advance
    Any welder that knows his stuff can weld it for you.
    FYI, Your chassis is not a Workhorse, it is Chevrolet. Workhorse bought the chassis in 1999.
  • a good weld shop will know how to tackle this its not a hard job.I,ve had things welded close to the fuel tank before.
