ChuckSteed
Mar 23, 2019Explorer
On a hydraulic slide out system by Lippert there are not any “limit switches” in the system... the components would be...
.. hydraulic solenoid valve...
.. Hig( pressure cutoff switch
If you hold the extend or retract button in the slides will move in or out to full position and hydraulic pressure will build and activate the high pressure limit switch which in turn shuts off the hyd pump motor
You need to download the thru the frame Lippert slide out manual and there is a section that will show and guide you thru how to adjust the travel on the slides...
Each slide has an adjustment for extend and retract travel...
One has loosened up and slide is out of adjustment. ....Or something is in the way of that slideout preventing it from extending completely
https://www.lci1.com/images/support/lipsheet/0131.pdf
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
