Chris_Bryant
Mar 13, 2014Explorer II
jody h wrote:Chris Bryant wrote:
The thermal fuse on the cooling unit has tripped- like it is supposed to.
So that's what it is. Is there any way to check that?
It's on the cooling unit- you will get a new one with a replacement unit. The 12 volt power goes from the terminal block to the 2 thermal fuses (one on the cooling unit for overheat, one flame fuse next to the burner), then to the circuit board.
The one on the cooling unit usually has a reset button.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
