BobsYourUncle
Mar 13, 2014Nomad
Chris Bryant wrote:
It's on the cooling unit- you will get a new one with a replacement unit. The 12 volt power goes from the terminal block to the 2 thermal fuses (one on the cooling unit for overheat, one flame fuse next to the burner), then to the circuit board.
The one on the cooling unit usually has a reset button.
Chris, I wasn't aware of these fuses.
So are these in addition to the 2 on the circuit board?
I never looked for external fuses or circuit breaker outside the board.
Can you tell us exactly what these 2 fuses do? That is what do they interrupt to stop the fridge?
Does the flame fuse stop the flame?
