mhaller28
May 05, 2014Explorer
dougrainer wrote:mhaller28 wrote:
There is a voluntary recall on this model. It said if it is leaking ammonia and yellow liquid to shut it off and have it serviced immediately. This was on dometic ' s website!
The recall involves ONLY adding a temp/heat shield. IF it leaks there is no replacement offered for free. Doug
Thank you! :-) Has anyone had troubles with it just wanting to go straight to gas (even with the button in the correct position for it to go to auto) and bypassing the electric? It is plugged in to the correct voltage but after attempting to ignite to gas it says check. Fuses are all good and do not see a reset button either. No seen/known leaks.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
