wa8yxm
Nov 06, 2014Explorer III
wa8yxm wrote:
If your voltage detector found no voltage, but the wires arced. FAULTY VOLTAGE DETECTOR.
Can not comment on the GFCI
Wire Trackers (harbor freight sells one) may assist you in tracing the problem down.
One thought.. Some electrical inspectors need to be charged with stupidity.
It may be that the seller was told he needed to install GFCI's (you usually do not on older houses, Grandfather clauses usually apply)
So to make the inspector happy he put in a GFCI, in the proper place, never bothering to hook it up, See there is is. Inspector checks off the box (Without ever testing it) and moves on.
(When I look at what the inspector passed in the house I used to own.. I can believe that story.. He scared me,, It is not good when I know more than a so-called professional inspector).
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
