Vintage465
Mar 10, 2020Nomad
If I went to a Progressive Dynamics Converter.......
So I'm always looking to my next upgrade for my charging of the 4-6v GC batteries. Knowing that the WFCO converter my rig came with is next to useless on it's own, add to that the fact that there is 18' of #8 wire to drop the theoretical charging voltage from a possible 14.4 to 13.4.
If I went to a Progressive Dynamics retrofit I'd be re-conductoring to #1 or #2 wire from the converter to the batteries. I was reading that their charging profile is to pack 14.4 or 14.6 volts to 90% of the charge. Then somewhat float it up to 100% with 13.5-ish volts? To me this doesn't really seem like that great of "wizardry" even though it's called the charge wizard.
For those of you who've installed them, how well does the wizardry work? I would only be using it when there isn't enough sunlight to get at least 90% with my solar. When we were at the Mojave Desert for Thanksgiving this last year I could have used it one day to bring my batteries to 100%
Thoughts?
Thanks,
Thoughts?
Thanks,
