rjsurfer's avatar
rjsurfer
I'm guessing an A/B/Both battery selector sw is okay?
Just added two new T 105's in preparation for adding an inverter and eventually solar. The original two 105's are 3 years old and are in perfect shape, from what I have read mixing the 4 in a series parallel combo isn't the best way to go.
I'm thinking if I keep the sets together and use a marine a/b/both selector switch I can charge each set individually then combine them when I'm running the inverter to get maximum amps....I know its a little more work to keep track of the charging but it will keep my mind sharp:-)
Any problems with this?
Ron W.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
