wealthwise's avatar
wealthwise
Inner Dual Wheel Extenders Impossble to install.
Since I got my two inner wheels replaced more than a year ago, I have not been able to check the air, we picked up some of these Air Guard extenders in Alabama, thought it would be easy enough to install, the instructions say to place the extender though the hand hold and thread onto inner wheel valve as shown, seems easy enough except for two problems 1. you can't fit your and though the hole and 2. you can't align the extender with the valve even with the use of long needle nose pliers even though the side between the inner and outer tires, so does anyone know if there is a trick to this, or does the out wheel have to be off when these are installed?
Thanks
  • I was able to get on with big needle nose plyers with the long handles. Came in perfect because I was wanting a pair of those anyways. Mine are the type that you screw on, no external noses or brackets $7 bucks each. One kept wiggling around, put in second little rubber gasket and torqued pretty hard and a little bit of lock tight. Also run gator caps, no more problems. But some people have some pretty fancy ones, if you do a search. I have steel OEM wheels. Measuring air pressure is like looking at your fuel gauge. Do so often.
  • sch911 wrote:
    I had to remove the outer dualie to install these on mine. Not such a big job...
    X2
  • I had to remove the outer dualie to install these on mine. Not such a big job...
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
