Racorman
Jul 23, 2015Explorer
smkettner wrote:
Again I would skip the 15 ground connection.
Still not 'perfect' but close as you will get without a major effort.
Now lets talk about how you are charging those batteries to help with the needed capacity.
Fixed......
I'm planning on installing (3) 300 watt solar panels that will fit well on my roof. Because these will be 900 watts of high voltage panels I'm going to install an OUTBACK FM-80 controller.
Any thoughts about hooking up the Battery MINDer Model OBD-12 Battery tester/desulfator which activates when charging your batteries from an alternator, solar array, generator, or other power source. Quick connector input allows for easy use of additional BatteryMINDer charger / maintainer devices. Built in battery tester indicators show battery condition. Patented full-time high frequency sweep pulse desulfation is designed to reverse and eliminate battery sulfation, the #1 cause of early battery failure.
http://www.batteryminders.com/12v-atv-jet-ski-onboard-battery-charger
