brulaz's avatar
brulaz
Inverter Bonding Neutral to Ground
Here's a picture of how a Kisae 2000W inverter's GFCI outlet is wired.
The neutral side is not bonded to socket ground other than through a capacitor, as is the hot side. I guess the caps have something to do with the GFCI? Otherwise there's nothing connected to Grd on the socket internally.
However the neutral is connected to the case ground via a green wire with a big black blob in it. Any ideas what that would be?
And case ground will go to the chassis, so this socket's AC Neutral will go to chassis via the blob.
But over at the trailer's AC distribution centre, AC Grd goes to chassis. AC neutral is not bonded to AC Grd over there.
So it seems AC neutral will be bonded to AC ground via the chassis when this inverter is connected? (Initially will just run an extension cord from the inverter to the trailer's 120V input)
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 18, 2025
