pauldub's avatar
pauldub
Inverter grounding to batt or chassis
I'm looking for some input regarding the ground (negative, not neutral) connection for my 1800 watt inverter. I need about 10 of wire to run it back to the battery or I can ground it to the motor home frame with less than 2' of wire. I suspect that the frame will provide a lower resistance return to the battery than any reasonable size wire; however, not knowing the resistance of the frame, it hard to be certain. Thoughts?
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
