dave17352's avatar
dave17352
Explorer II
Jun 26, 2019
Inverter in repurposed generator locatoin with agm batteries
I am thinking about upgrading my solar some and this is my plan.
I will locate my 2 agm deep cycles, 30 amp mppt solar controller and 2000 watt inverter all in the old generator location that I removed several years ago. Presently there is just one agm in there now.
The generator comppartmment is well vented as the orignal door is on the compartment. There is plenty of room for this equipment and air movement.
My concerns are
All though agm's should not out gas except if extreme overcharging occurs. It still makes me a little nervous.
The second concern is The propane compartment is above the genrator compartment. That kind of makes me nervous. Like what if the propane leaks and falls and kinda get side tracked into the generator compartment below. Of course the original design had the generator running below the propane:).
So what do you all think?
This is on my 98 Lance Truck Camper
Thanks
Dave
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 09, 2026
