Cptnvideo
Sep 29, 2023Nomad
Where is your transfer switch located? In my Solitude which is pre-wired for a generator but does not have one, the wires to my inverter/charger come from the transfer switch which is located just to the rear of the pass thru compartment. Then the output of the inverter is wired to the AC distribution panel. The OEM converter is unplugged.
With this configuration, shore power is passed thru the inverter and I am able to use the load share feature on the inverter.
I also have a lot of solar.
With your proposal, you would want to make DANG sure inverter is turned off before running the generator.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
