timelinex
Sep 29, 2023Explorer
Cptnvideo wrote:
If the inverter you are installing has a 20 amp outlet on it, you could simply pick up a 20 amp dog bone adapter and plug your shore cord directly into it.
I did that on a previous Class C with a 1500 watt inverter I added.
And I forgot, you absolutely want the inverter as close to the batteries as possible.
Where in AZ are you?
I recognize that is an option , but its a hassle lugging the big cord. Also I believe the inverter is limited in output in the plugs vs hardwire (may be 15amp plugs)
I'll do this temporarily if I can't find an otherwise easy solution
I'm in Cave Creek
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
