delwhjr
Aug 03, 2019Explorer
mike-uswest wrote:
I have a 2016 Arctic Fox 25Y Travel Trailer that has the iRV AM-FM iRV-34 radio in it and is giving me problems. Most of the time after it has been sitting for awhile, and sometimes even when we have been using it, it will not start with the remote or with the switch on the radio. The switch has a light on, so it appears to be getting power. I found the 20 amp fuse, and if I remove it and put it back in, it gives a little spark and will work most of the time after. I replaced it with a new fuse, and no change. But the switch on the radio always shows power is getting there at all times. I put some Ox-Gard on the fuse, an aluminum wire antioxidant and that didn't help. Does anybody have any ideas? Thanks for the help.
Mike
Contact IRV
iRV Support
Contact: Nelson Arzadon
Work: 574-970-8348
Mobile: 574-850-6334
Email: [email protected]
or
[email protected]
I had a irv66 that was causing problems and they helped out quickly and solved my problem.
