RJsfishin
Mar 15, 2014Explorer
First of all, anytime you parallel 2 12v batteries of any size together, it becomes one (1) larger 12v battery. If you cannot understand that, then give it up !
Second, read this quote from the OP:
Yes MS is a Marine Starting battery, which has a higher CCA rating than a true Deep Cycle, but is also rated for deep cycling.
What part of this was not read or understood ?
The 2 batteries will discharge and charge equally, but maybe should not be discharged any more then necessary, only to prolong the life of the MS.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
