pianotuna
Mar 16, 2014Nomad III
Hi,
You can do it while discharging at a high rate. Doing it while charging doesn't work too well as each chemistry type wants a different charge voltage. Connecting them in parallel while resting is a bad idea as one will act as a parasite on the other.
It is definitely not "best practise".
Lowsuv wrote:
Is it okay to parallel an AGM battery with a conventional battery ?
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
