Camp__Forrest__
Oct 08, 2014Explorer
mena661 wrote:
How not to have this happen again:
1. Don't take batteries taken down to 10V and then not charge up to 100% properly.
2. Only leaving batteries to charge for 2 days.
I didn't realize two days wasn't long enough to charge them back up. This is probably why this happened the last two weeks I was there. I was probably getting enough charge to get me through M-Th night for the first four weeks, but not reaching full charge. Eventually, I didn't get enough to last me the few days. In other words, I may have been heading into the field with (95%, then 90%, then 85%, and so on.)
mena661 wrote:
The fix! :B
1. Don't take your batteries down to 10V. Ever.
2. You need a Black and Decker VEC1093DBD 40 amp portable charger. Only use the built in crappy converter for float charging and when you're on full hookups (leave your rig plugged in 24/7 when not camping and check water levels once a month).
Can the charger help recover the batteries I have or is this for future reference?
mena661 wrote:
4. If you run your batts to 10V again, break out the hydrometer, you're going to need to know FOR SURE that the VEC got them back to 100%.
What do I do with the hydrometer? The "12V" site only mentions using it to test. Do I need to add something if they are low or is this just for information purposes?
MNtundraRet wrote:Fortunately, the new camper has a generator. I actually have a Honda 2000, but I didn't take it because I knew from experience that I could go a week. I didn't realize how far they were draining and how long they took to charge.
Your problem is caused by not having a generator.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 22, 2026
