oyly's avatar
oyly
Fridge on 12V killing the batteries
Just came back from the shop where I got my new batteries after I toasted my first set. I got them replaced 5 months ago, and already they were performing poorly, even thought they were supposed to be real good quality deep-cycle batteries. So I just wanted them to put their battery tester on them to confirm my suspicions, and sure enough, they were no good. Very generously, they replaced them under warranty, even though I most likely damaged them with improper use. When talking to the staff, they asked me about my refridgerator. I said it runs three ways, on LP, 120V and 12V. They said I should never run it on 12V since this will damage the batteries. I tried to explain them that when the batteries are down, after driving the RV for a couple of hours, the batteries are fully charged, so even if the fridge pulls a lot of power, the alternator is more than powerful enough for both this and giving the batteries a good charge.
The still insisted it was not good to run the fridge on 12V. Now, I am an electrical engineer, and I cannot with my best imagination understand why it would be bad to run the fridge on 12V if the batteries are charged after a drive. The fridge should just lower the amount of current available to charge the batteries. And if that was a problem, then it should also be a problem to use a small charger to charge the batteries. I've never heard that it is bad for the batteries to be charged with a small current, only that it will take longer.
What do you think? Are the staff at this shop just superstitious, or do they have a point?
