RJsfishin
Oct 12, 2014Explorer
Niner, you sound like a stuck record ! Of course you were still in diapers when that happened.
Are you all senile or what,....97 amps,....out of a little wall charger ???
The charger is showing 97% charged. At 95% it is about 15.8 volts
It is on the lowest amp setting of 4, including the "75 amp engine start"
The charger itself does not show amps, or voltage, except 12v, because its on a 12v batt. The display flashes between %age and 12v.
In any amp setting, it shuts down at 100%, but maintains in the lowest setting only, at 13.3v. It finishes at 16+ volts in all 3 amp settings.
Its not the perfect charger, but show me another that finishes at 16.5 volts.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
