jandjbaums
Oct 12, 2014Explorer
NinerBikes wrote:Thats why I choose to run non-ethenol in all my engines, snowblower, log splitter, saws, genny etc.JiminDenver wrote:
Those Honda generators are sure finicky. I pulled the snow blower out yesterday to get it ready for winter and saw a half a tank of gas from last year. Fearing the worse I pulled the rope and it fired right up.
A 9 or 10 HP Honda motor and the size of it's brass jets does not get affected as severely as a 49cc or 99cc Honda generator with it's tiny carbs and jets. Just a fact of life and the nature of the beasts. Lets not compare apples and watermelons, OK? ;-) It's about scaleability not applying in this case.
Now, then... the OP needs a super duper 16.0V or barely higher charger that can grunt out and hold a C/20 battery capacity AMPERAGE charge rate, to top charge and equalize charge his battery. Any more suggestions?
I use an early 1980's Sears Automotive 12V 6 amp/2 amp Manual Charger to perform this function on my battery. It does make 16.0V in 6 amp mode. It makes 13.6V in 2 amp mode.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
