opnspaces
May 20, 2019Navigator III
keeping the panel on the roof is not a weight issue but an attachment issue for wind getting underneath.
Change it up and open a new ticket and ask Jayco if there are wood trusses or what is under the roof deck allowing you to walk on it. See if they will send you a diagram for where the trusses are, or you can probably figure it out by the amount of flex underfoot while you're up there.
If wood trusses I would say it;s standard CYA and you can mount them.
