BruceMc's avatar
BruceMc
Explorer III
Jan 06, 2014
Kwikee step logic
Having just purchased a new Kwikee Sires 28 step for our class C, I dug it out of the box and read the directions. Gee, easy! Right.
Wire colors:
Red - power
Green - ground
Brown - to magnetic door switch, then to ground
White - to switch, then to power
Yellow - to ignition
I tied red, green to my battery, positive and negative.
Step opened,
I expected I could touch yellow or (edit) white to power and have it close. Nope.
So... I thought it was broken, out of the box. I then set up all wires with switches to power/ground per the directions.
Here's the setup:
Power - Red
Ground - Green
Brown - switch - ground
Yellow - switch - power
White - switch - power
Here's how it works:
Connect Red to power, Green to ground, with all switches off - Steps Open. (Door open, Ign off, Override off)
Close the door - Brown grounds - steps close.
Open the door - Brown opens - steps open.
Flip override switch on - White to power, Step stay closed. (yep, closed)
Open the door - Brown grounds - steps open.
Close the door - Brown opens - step stay open because White is tied to power.
Open/Close door, step stays extended because override is on, White is tied to power.
Door closed - Brown grounded, Override on, White to power, steps extended.
Turn Ign on - Yellow to Power - Steps close.
Turn Ign off - Yellow open, Steps remain closed.
Open door, steps open.
Close door, steps stay open because override is on.
The basic logic - No matter the other switches, anytime the door is opened, the steps open, if not already open.
If the door is closed, steps stay open if override on, if ign turned on, steps close.
Interesting logic, but it all works. I can see how it's supposed to work now...
  • The "logic" is nothing new. Kwikee steps have a Last out feature. That means regardless of what you have done, emgine OFF/Engine ON/wall switch Off or On, the last out feature means when the door is opened, Brown wire magnetic switch/ the steps extend. This is to prevent the steps from NOT extending and you fall out of the RV. Doug
  • Bruce,
    Your 1st post "logic" is the same way my steps functioned when new
    To stop the steps coming out we have a frig magnet handy that I stick to the door switch (actually to the wall very close the switch) - it completely stops the steps from coming out. The system thinks the door is closed.
    Itasca / Winni wired mine
    Door switch power from ignition switch and main power from the Engine battery before the disconnect solenoid. The disconnect switch had no effect on the operation of the steps. The Engine battery always had a unwanted drain.
    I changed the wiring by moving the main power to the house batteries after the disconnect switch leaving alone the ignition switch connection. Turn off the house batteries and the steps do not function. Nice when getting access to the batteries which are located inside under the stairs
    We always dry camp with solar charging the house batteries
    No need for an extra load on the engine battery which is most of the time isolated from the House battery bank
    The step lamp and the motor plus a small parasitic load from the controller were draining the engine battery unnecessarily
  • I promised myself I would stay out of Kwikee step discussions but I can't help myself. First I have to say Kwikee as an independent company no longer exists, it is now Power Gear. They do not deal with end users, they deal with distributors and dealers only!
    They do however have a great library of manuals and part lists on line. I think you should download and print out Owners Manual #888. On pages 7 thru 11 inclusive is the trouble shooting section. You will need at the minimum a DC volt meter with a 12 volt scale.
    The mechanics and electronics are simple and easy to trouble shoot if you read and follow the manual. Page 3, is especially important so you know what the proper operation should be.
  • D.E.Bishop, Agreed! I have the #888 Owners Manual that came with the step, of course. Once I read the info and followed the troubleshooting guide, I then understood the theory of operation, as simple as it is. The thing that threw me off was:
    If the ign is energized, then I thought the steps should retract. They do ONLY if the door is closed.
    If the steps are closed, and the override switch is turned on, then I thought the steps should extend. They do not until the door is opened. Then they stay extended when the door is closed.
    Subtle nuances...
  • Great post Bruce!
    The system is designed so you cannot open the door without the steps being out.
    It won't hurt the system if the steps hit something and do not go out all the way. (it might hurt that corvette you parked too close to)
    The steps ALWAYS run 100% off chassis power, and are not affected by any power disconnect switches.
    The door opens, the steps are out, period.
  • The suggestion to call Kwickee is not a good one. Over the past several years of RV ownership I have never been successful getting an answer or a call back from them.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
