tenbear
Sep 03, 2013Explorer
If you can follow the wires, the negative wire will be connected to the chassis. The positive may or may not go thru a fuse and eventually end up at the converter and power distribution panel. Its probably easier to follow the negative wire.
Normally, when the two wires are black and white, the black wire will be the positive wire.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
