alliemac9
May 23, 2014Explorer
Interesting idea - are you all suggesting that I find a cabinet door to cover that lower area so I can remove the veneer panel, install the controller there, then have access via a door?
Would need to move that air intake in that case (unless I wanted foil tube to open/close with the door), but it might fit in the thicker wood above the veneer panel. Time to go unscrew the vent and feel around in there to see how much space there really is...
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 24, 2026
