AlbertaNewbie
May 23, 2014Explorer
alliemac9 wrote:
@Alberta - so you don't think being in the same cabinet as the furnace would be a problem for the CC? I was contemplating something similar - creating a "backboard" out of plywood to mount things on for easier visibility/access.
While there's probably room in the existing shallow cabinet, we do utilize it regularly so I'd be inclined to replace the veneer around the vent with a cabinet door and install components there. I'd then probably put the TriMetric next to the panel between the existing cabinet and the new lower cabinet. So, the only thing in this new cabinet would be the CC, correct? And associating wiring junction boxes or something?
Does anyone know if there are any restrictions as to the orientation of a TriStar CC? (Sorry - I know - read the manual...just haven't gotten to that point yet.) Can it lay flat on its back if needed?
No issues with placing in same cab as furnace. The tristar should be mounted vertically to ensure cooling, particularily when nearing 50% or more of the rated amperage. Having jb's and other wiring in there should not be a problem either.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
