przao's avatar
przao
LED bulb replacement problem
I recently installed 15 LED replacement bulbs in our fiver - replaced nearly all of the incandescent bulbs in the rig. We went on the long trip earlier this summer and while reading at night, we first saw one bulb become bright, then POOF! it blew. When I checked it, the LEDs themselves appeared burnt, and the end of the unit was discolored. As I continued my examination, another bulb did the same thing! Off they go, and when I checked, at least half of the 15 were discolored.
The next day I called my RV place and told them of my dissatisfaction - they offered to take them back, but we were already on the trip - luckily I still had the incandescents to put back in their place.
After returning home and doing research with the RV place, we discovered that the LED would work to a maximum of 14 volts - my trailer sometimes sits at 13.6 v, likely higher at times, so the bulbs blew. The RV place exchanged all 15 with different bulbs rated to 30 volts. We have subsequently taken another trip and the new bulbs work like a charm - hardly any warmth produced.
Sorry I don't recall the manufacturer of the low end bulbs, but I'd recommend looking at the voltage rating on the package and make sure that it is well over 14 volts just in case your rig sometimes runs high as mine does.
  • westend wrote:
    Thanks for the heads up on that.
    Do you know if it was the controller on the bulb or if it was the LED's themselves that went "poof"?
    Where did you buy the bulbs, at a dealership?
    It looked like the LEDs themselves, but I am not positive. yes, from an RV dealership who took them off the shelves and returned everything to the manufacturer. The replacement bulbs were 50% more expensive.
  • It's so easy to get ripped off with LEDs. Blue light, dim light, voltage intolerance, flickering...
    Good voltage-tolerant LEDs are 'usually' more expensive.
  • We replaced all of our incandescents with LEDs and used flatpanels throughout with the exception of a few cobb style LEDs we purchased locally at a major truck stop.
    Our Iota converter bulk charges at 14.8Vdc and these cobb style LEDs only lasted 2 years before they started acting weird, they did contain regulators that obviously didn't like the higher charging voltage of our converter.
    On the other hand, the 14 flatpanel LEDs we purchased have worked flawlessly without a single failure over the last 3 years and they do not contain a voltage regulator and cost 1/5 of what I paid for the cobb style LEDs I purchased locally.
  • Thanks for the heads up on that.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
