profdant139's avatar
profdant139
Explorer II
Dec 10, 2015
LED bulbs: can they function on both 12V and 120V?
I stopped in at an electronics store -- told the guy I wanted to build a small 12v LED table lamp (for reading) that would plug into my cigarette lighter socket in my RV. He had a display of some really nice looking bulbs, in either square or in-line configurations, warm white light, for four dollars each. They were labelled at 1.4 watts, which (I think) draws 0.11 amps -- essentially nothing. The bulb had two wires running out the side -- no socket, no wedge, just two wires. He said, "Just hook this up to your cigarette lighter plug, stick it in the socket, and that's it."
But his in-store display was (I think) powering them with ordinary 120V current -- is it possible that the bulbs do not care whether it's 12V or 120V current? If that's true, it's an easy and cheap project.
So that is my question -- I thought (naively) that bulbs are designed for a certain current. Can I just hook these babies to a cigarette plug, and that's all? Seems too easy.
Thanks in advance for your advice.
(PS -- obviously, I will build a lamp stand, with an arm, so that the light will extend over the reading material, with the wiring running in a channel inside the structure of the lamp. But that is easy -- simple woodworking.)
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
