Bigdog's avatar
Bigdog
LED tail lights.
I decided that I would try and change the tail lights on my Tradewinds over to LEDs and see if they are any brighter. I pulled the old bulb,got the number, Sylvania 3457 and headed for the rv store. Looked and looked and finally the counter guy found one package of Revolution 3157-280A and I checked and they were the replacement for the 3457s that I have. Took them home and installed one on one side and hit the flashers and wow, was it dim. Pulled it back out and checked the package again and way down at the bottom in very small letters it said, Porch light,color-amber.
Gonna be taking them back tomorrow and am wondering if there is any advantage to changing them out after all as the bulbs are really bright.. Also what would be the best ones to use. I did look at changing the whole units out,but those replacements are over $200 a pair and that's not worth it.
  • j-d's avatar
    j-d
    Explorer II
    Beemerphile nailed it. Replace the assemblies or don't bother.
    I got this type here They look like this
    except I got the triples with backup lights. $50 each for the ones pictured and $60 each for the triples.
    And they are AWESOME!!!
  • Replacing only the tail lamp with an LED will most always disappoint. You should replace the entire fixture with an LED fixture.
    Your original lamp was 402 lumen and 38 lumen. For an LED to be brighter it has to beat these measurements plus be properly designed to work in a reflector type fixture.
  • They make all kinds of 3157 led bulbs....just make sure you get a bright one.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
